Do I need Longer Shocks?
El Paso TX
I have the OME Medium springs all around,and the n73firm shocks I then have added the ARB Bumper and Warner 8000 winch so I lost aproximately .5" on the front springs.
I was going to purchase the heavy springs, but they only add .82" of an inch in hight. J's should add 1 inch! So since I just purchased the Metal Tech 1.5" spacers to add to my medium srings do I need to purchase longer shocks, or should I be ok with the original OME shocks?
There are several people running heavies springs in the front without any additional weight and they are ok with the regular shocks! So theoretically I should be ok?
I have in the front 22.5" from hub to fender and rear is 24"
With the Metal Tech Spacers 1.5" should even it out, do I need to change the shocks to the N73L?:crybaby:
Iv'e been running the OME shocks that came with my Heavy kit. I dont remember the part number, but I'm sure someone who chimes into this thread will know. You can go and purchase shocks that are longer, but you'll need to ask yourself if its really worth the added expense? There are several things that need to be considered when you think about added drop on the front suspension...
No I do not need lomger shocks!
I go by a simple formula. I measure my shocks at full extension and at rest when mounted. If the shocks don't come out pretty much in the middle between full extension and full compression when at rest, I need longer or shorter shocks depending on the results.
Shocks count much for comfort in riding and driving. A good fit is very important.
Kalawang
