I am looking at this 1994 fzj80 258k miles because it is in my price range but obviously have some concerns due to the high miles. I have included pics of under the front end where you can see some leaking but I am not sure if it is normal or an issue. any info would be greatly appreciated just want to know what I should look out for. Thanks
It has Birf soup. Likely needs an axle seal. The good news is that if it isn't clicking on tight turns, the birfs are OK. Lots of folks run the birfs with gear oil in them for years. Not recommended, but it isn't the end of the world. Looks pretty clean otherwise.
From the outside they look really good for 258k if they've never been serviced before but the diff fluid might be low too. From what I've read, you'll hear a clicking sound when you drive in tight circles with the Cruiser.
If the current owner does not have service records I would budget $2k to baseline the Cruiser which would include new tires.
So Do you think that it is definatly birf soup or is it possible that the leaks are something else? I ask because I have seen on some of the other posts where it will start leaking from the outside and be visible on the wheel.
To really get a sense of what's going on, you need to take a "look" at the inside of the knuckle, and the diff.
For the knuckle, grab a long zip tie, remove the square plug on the top/front of the knuckle (12mm wrench I think). Stick the zip tie down inside...if you get a "soup" that's partly grease and partly gear oil...(you should just get nice clean grease.)
Then check the diff...remove the top plug (the fill plug). Stick your finger inside...it should be nice gear oil. If it's "soup" then...
Since doing a front axle service isn't such a big deal (given the info and support on MUD) it's sortof in your favor if you find birf soup...as you can use it to negotiate a better price.
I was wondering if mine needed changing too??? I have attached some pictures of the knuckle and a sample of grease. For the time being, I added 1/2 tube of Synthetic Moly Grease to each side.
Thanks for the info guys I really appreciate it. What sort of things should look out for as far as motor and tranny being that they both have 260k on them. I know these motors were sort of notorious for head gasket failure and want to make sure there are no problems If I do purchase. Also what kind of miles are people getting out of these motors? Am I crazy for considering one with 260k on it?
Thanks again guys this site is very helpful.....and I dont even have a LC yet!
A little seep is normal, but I am looking at the grease splattered all over the axle housing and the spring. Agree that birf soup is not the end of the world though.
Check the tranny fluid for a burnt smell, do the "bubble test" check rear main, phh, rear heater hoses. Lots of threads about that.
