Do I have a 3FE or 1FZ engine???
VA
I have a 1996 L/C and was wondering which engine I have? Sorry, if this is a stupid question.
Also, I may need to replace my alternator soon. When starting, it acts as if the battery is going dead (slow turning of the engine but it starts). This is only in the morning after sitting all night. No lights are left on or anything. With that, do I replace the brushes or the bearings or the alternator? The battery is only 6 months old. Thanks!
Rounded valve cover = 3FE.
Squared off valve cover = 1FZ.
They changed over to the 1FZ in late 1993/94, so yours, being a 96, has the 1FZ.
Wasn' t tha battery. I had it checked. They said something is draining the battery.
I had a problem with a battery a few years back with my Explorer where they said "it wasn't the battery :confused:" My truck was completly dead I tried everything I was getting to leave on a trip in the next couple of hours. Could not find anything that it could be. Replaced the battery no more problems :idea: Just my experiance
It's not the battery. Something is DRAINING the battery. (that is what i was told)
Ok I get that...........
my comment still holds for me.
you havn't said what bat. you have and regardless of what the culprit turns out to be I am a big believer in good batteries. JMHO.
Get a multi meter and pull your fuses one by one (replace them as you go along). Set the multimeter to amp mode and bridge the receptacles of the fuse socket you're at and see if there is current (appreciable) across it.
If something really is trickle-draining your battery, it'll stand out like a sore thumb when you do them all. At least that will give you somewhere to start looking for the problem. :beer:
Oh, and get a good battery :flipoff2:
