Dizzy ?
How do you know if the vac advance works on a dizzy? Is it possible to test w/o connecting to vacuum? Mine has a white dial (possibly adjuster?) on the opposite end from the vac port. When I turn, push, etc. the white dial/adjuster, the points plate doesn't move...that is when the dizzy was out of the engine.
TIA,
Rob
1976 FJ40
suck on the line that goes to the advance port on the dizzy.....the RPM should go up(if on the motor) if not on the motor you will still be able to see the advancer move on the dizzy. I don't think turning the dial with the dizzy out will make the advancer(fof lack of a better word) it actaully turns the dizzy body itself, just like if you were to loosen the hold down clamp..........but I might be wrong
when hooked up to the motor, hook a timing light up, then turn the little dial on the dizzy, the timing mark should move
TIA,
Rob
1976 FJ40
