DIY: Sunroof Weatherstrip Replacement
I just tackled mine. Looking at the new seal, the groove in the seal looks shallow but there is a soft flap in it and below that flap is the cavity where the plastic rim sits. I was thinking about how to get the adhesive down in there and had an ah ha! moment. I took a needle used to air up basketballs, footballs and cut the end off. I heated up the end of some vinyl 3/16” tubing and pressed the threaded end into the tubing. Then heated the other end and slid it over the adhesive nozzle. It was hard to see how much adhesive I got in there but it was flowing out of the needle pretty well. I then smeared a coat on the plastic rim and then did another small bead back in the weather strip groove. This time keeping it on on top of the flap (not as deep into the groove).
Man, it was tough to press it all the way on. I used squeeze clamps to help press it on and it mostly held but still wanted to lift here and there. I had pre cut some 1/4” x 1 1/2” trim strips so used those with a bunch of clamps to hold it over night.
We’ll see how it looks in the morning.
Thanks to this thread I was brave enough to do this job myself. For thext person doing this - check if there is already preapplied adhesive on the new part! I am 90% sure this was the case, but cannot confirm it now after I've finished it. Here's what happened:
I removed it the proper way by unscrewing the "golden nuts", however several of the clips on the plastic covers broke no matter how gentle I tried to be while pulling. Oh well, I'll blame the 24 years old plastic. I really took my time cleaning the old adhesive. An old toothbrush worked pretty well for goo-gone application tool. I am pretty sure it was very clean before continuing. Next I did a what I thought would be a test round snapping the new rubber in place wothout any glue. Since a few members here reported how difficult it is to snap the thing in place and keep it in place, I decided to go all the way on the "test" round, snap it all the way, turn around the glass, inspect the top so I know what to aim for when I apply the adhesive.
After doing this, I start removing it to apply the adhesive. I pull a little bit and to my surprise see glue stretching between the new weatherstrip and the plastic trim piece. My first thought was "Oh well, apparently I didn't clean it as well as I thought". I pull a little bit more and the amount of glue stretching between the two parts just didn't make sense given the amount of time I spent cleaning the old stuff and the condition it was after all that cleaning. This must be preapplied adhesive on the new part, I thought. On the spot I made the decision to stop pulling and snap the small part of it already pulled back in place. Now I think there actually is preapplied adhesive in the correct amount and only in the small groove where it actually snaps, so that there is no chance to notice it unless specifically looking for it.
Either way I used baja's idea to apply some additional adhesive between the new weatherstrip and the plastic trim piece and between the glass and the plastic trim piece. For the 3M adhesive tube size and the needle I found there was no need for additional tubing - just some PVC tape did the trick.
One last thing - when putting it back in place don't tighten the nuts while in tilted position. It might refuse to close :) Close with loose nuts, make sure it's all the way closed by looking at the top and helping it a bit if needed. Then tighten the nuts.
Pop it off with a plastic trim remover strait down and there are 4 10mm bolts under it. ( Mine bolts where silver, I feel shorted) Pop front and back off first. Yes, the glass has to come out. Literally takes like 2 mins to remove it if that. I used 3M window urethane on mine and ran a bead around the plastic strip because that is were it is probably leaking.
This is where I ran the bead around the top on the inside of the plastic. I taped off about a 1/4 around the entire area. Mine was leaking in that seam in the above picture for sure.
Looks like I ran into the same issue here too after a few days of rain here in CA. I noticed that there was a small drip coming from the sun roof on the length side toward the back of the vehicle.
I took off the trimming and noticed water marks between the plastic. At this point I am leaning towards resealing with silicone unless there is any other suggestions for an alternative fix by the community.
Did you end up applying the 3M seal to the outside (on the outside facing plastic of the sun roof) or inside of the plastic stripping? Below is a picture from inside of the cabin looking at sunroof with the plastic trim removed.
When my sunroof leaked it was the trim to the glass. I carefully masked off the seam between the glass and trim with fine line tape and smeared it with Permatex The Right Stuff. Peeled tape off and problem solved.
The rubber 'gasket' is there to stop major water and wind noise, but water will get past it and leak onto the drip channels and out the sunroof drains front and back.
The glass comes with the trim and I don't believe it is available separately.
This is also brilliant. Did you consider using window adhesive?
Reviving this thread with a Car Care Nut video about a 100 series sunroof replacement.
The guy always follows the book, and in the video he also replaces the seal. Sadly he didn’t concentrate in that specific task since it was edited to a higher speed to save time, but you can clearly see that he didn’t use any glue, only silicon spray to lube the seal back in place.
Starts from 26.30:
Double reviving this thread. I was replacing my seal with the help of this thread and the plastic trim had separated so bad it started to peal away from the glass. I bit the bullet and ordered a new sunroof from Toyota and a seal, however when it arrived I opened it up to find it already had a seal installed. I took that as a win and I popped in the glass and stashed the extra seal in my parts bin.
I am going to see if I can glue back the plastic trim to the glass on the old one, any suggestions on what would be both thin and strong enough for that application?
I hate to do this to you, but any chance you could post a picture of the plastic trim separation? I'm having a tough time picturing it in my head.
I'll try to get one in the morning but where the crack develops at the front and rear is where it started pulling away. I could pull it off off the glass for about 4 inches on either side of the split. There is a U channel where the glass sits in that trim.
Adding some pictures from when I did mine this winter
I pulled back the plastic and cleaned the glass and plastic as best I could (lots of dirt and dust). IIRC I used 3M weatherstrip adhesive to put it back together. I then used clear silicone on the plastic seam to make that weathertight.
Can you clarify which seam you used silicone on? I still have a bad leak sometimes on the drivers side— haven’t been able to pin it down but I’ve only been testing the drains, windshield and roof rack mount not the sunroof itself.
Edit: I used 3m black weatherstrip adhesive for the gasket to glass
The sunroof seal has adhesive applied to the inner lip. You have to push it in place very hard to get it to pop out of the labyrinth they squirted it into. Once you get it, it pops audibly.
Here is what I was dealing with in the old glass. Not only had the seal failed but the plastic had broken away from the glass as well.
Oh yeah, that's not at all what I was picturing and that CA glue I suggested wouldn't tackle that level of separation. As TahoeZ suggested above, the 3M 5200 in black would be a good choice for that job. Good luck with the fix.
I’m going to try and fix it just out of curiosity I think. I’ve already got the new one in the 470. One more leak fixed.
I used the silicone on the seam where these pieces meet, all the way through the J channel that the seal attaches to. I believe that j channel seam gap is the root cause of a lot of leaks. The water drips down from there and does not hit the gutter Toyota designed, but runs through the plastic trim and then onto the sliding cover and eventually drips out on the interior somewhere.
