This is a DIY project to extend your CDL harness and make backlight feeder wires for additional switches such as fog lights, inverter, and heated seats. My main objective was feeding backlights and the CDL connector was the best choice for the project because it has the CDL connector cap which provides the requisite female end of the extension harness. I don't know if any of the other connectors can be matched with a female end. Usually they just plug into the back of a switch.
By the way, this is my second time doing this but first time documenting the process.
The key parts are the original CDL connector and cap. I don't know if this is a part that can be ordered but I acquired mine from the junk yard:
To make an easy project, pull the complete subharness that the CDL is attached to:
This is a picture of the sub-harness connector that can be found back near the ashtray, once you unplug this and all the switches you can pull the harness out as pictured above:
