Distributor upgrade 77-78
Eagle River, WI
I'm in the middle of upgrading my 1977 points dizzy to a 1978 electronic dizzy. I've done a number of searches and posts. Marking the rotor postion(pointing to the #4 cyl) #1 piston at the top of cyl. I took the old one out and put the new one in. When I put the new one in it seemed to slip into place. However, the rotor is pointing slightly towards the back of the mark. Should I have any concern for this difference? The dizzy seems to be seated all the way down. If this is right, I'm on to the wiring mystery. Thanks
could be off by a tooth one way or the other.. It will only effect timing. Again, make sure you got oil pressure when you fire it up.
When you put the new one back in the rotor should be pointing towards the #3 plug. As the gears engage the rotor then turns counterclockwise towards the #4 plug. Make sure the slot that the dizzy sits in to drive the oil pump is pointed towards #4, you can use a long screwdriver.
