Distributor O ring and Engine timing
SE South Dakota
I am trying to fix some oil leaks and would like to start with the distributor o-ring, where is the bolt located that holds it in place after the cap comes off? I have read quite a few post on the o-ring and but I have never seen the r&r explained for a dummy.
Also engine timing for dummies, does any one have any good links that explain the complete process?
Thanks
Chad
This would be a good thing for the faq now that many of the 80's are getting up there in years and miles
These helped somewhat
https://forum.ih8mud.com/80-series-tech/71747-distributor-o-ring.html
https://forum.ih8mud.com/80-series-tech/167726-oil-leak-distributor-cap-mount-what-do-i-need.html
If you're looking at the distributor from the DS fender side of the vehicle, the bolt is on the right side of the distributor... about 3 o'clock. Can't miss it.
As far as the other's, you should really consider getting the FSM. It provides the step-by-step procedures for both engine timing and distributor removal/replacement (which is a little tricky) plus all the handy pictures.
My $0.02, maybe someone will be willing to type it out, but you almost need the pictures, especially for shorting out the right terminals for setting timing.
:beer:
Rookie2
Thanks,
I would consider it but we dont plan to own it much longer. I have never checked or adj timing on any vehicle so iwas just looking for a generic tutorial to understand how its checked and adj.
