That is the one you cannot do much about.View attachment 2730894View attachment 2730895
Is this the “O s***” variety of leak or “wipe it and roll”? It’s 100% leaking from the non serviceable seal, but how do you know when to replace I guess is what I’m asking. Im not sure what qualifies as a slow leak, but every time the cruiser has been sitting a while, I see the spot on the belt.
Use electrical cleaner and spray out the dizzy, wipe, and assemble.
The one that drips on the alternator belts is the "dizzy O-RIng" that you pull the dizzy, change the O-Ring, and reinstall.
That said, after you clean out the interior of your dizzy, go fix your vacuum leaks, change the O-Ring on your oil fill cap, fix your PCV valve system, and clean your throttle body.
All of those things allow the engine to be under negative pressure all of the time. When the engine is under negative, the oil will not leak into the distributor. There is a vent hole on the dizzy that allows ambient air to be drawn in. If your engine crankcase is under pressure (such as blow-by from worn rings or lots of vacuum losses) then the oil will be pushed out of the weakest areas and this is one of those places.
I noticed my PCV port on the TB was clogged and I had to go in there with a screwdriver and scrape out all the goo. I drive mine a LOT and I noticed that there was a "wet spot" around the PCV valve grommet and that only happens under pressure.
