Distributor installation question TDC
Boise, Idaho
I am putting my engine together after the head gasket replacement. I have the valve cover on the engine and need to install the distributor. If i roll the crank until the timing marks are at 0, can I install the distributor? How do I make sure I am on the right stroke and not 180 degrees out? I'd like to avoid pulling the valve cover again if I don't have to.
Both valves on #1 cylinder should be at their highest point, closed. The FSM says to but your finger in the spark plug port and feel/listen for the pressure to build, then at the top of the stroke it will stop for a moment then suck (as the piston drops). TDC is that point when the air momentarily stops on your finger lined up with the timing marks. I had my wife give me a hand since its really tough to turn the engine, feel the hole, and watch the timing marks all at the same time.
On the 1FZ, going to need a really long finger to each the plug hole.:hillbilly: Can cover the spark plug tube or use a compression tester. Turn the motor in the correct direction, when pressure is detected, start watching for the timing mark.
I do have a compression tester so will try that approach. Thanks for the idea!
