Not sure on the wire colors, but maybe this will help...
- White and red wires from the igniter should plug into white/red from the distributor
- Black/yellow is power to the coil. A corresponding brown (light tan?) from the igniter via the double plug is hooked to the positive terminal of the coil for igniter power
- The white/black wire is ground to the ignitor case I believe. On mine it's a green wire I think. Alternator ground?
- I have a yellow wire that comes from the double plug that does nothing
- I have a black wire that could come from the negative terminal of the coil for a tachometer hookup.
First thing I would check is for 12v at the B/Y wire when the key is on. Without that 12v nothing will work, and you'll first need to figure what happened to the rest of the harness.
The wire colors may be different on your setup. But a quick check on the Haynes manual for a 78 shows 5 wires coming from the igniter. Two for the distributor (R&W), one ground (WB), one to coil +(BY), one to coil -(B).
Hope this didn't complicate things even more. Good luck!
