Distributor dilemna
I'm doing TBI conversion and I'm using 78 Toy electronic distributor which I took out the advance/retard mechanism. Now, how can I plug in my Toyota coil wire to GM ignition coil? Do I need to modify this ignition wire to fit? Thanks guys!!!
Why would you remove the vac advance?
And yes, you should be able to use the electronic trigger on your GM coil (why use the GM coil??)
