distributer / coil ?
Bozeman, MT
I have an aftermarket electronic ignition distributer on the f engine I bought. And I am about to the point of firing it all up, and I want to make sure that the stock coil is good enough or will I need to replace it? Also if it is good enough then can it just be hooked up the same way positive and negative or will it need anything else done to it? Thanks
Should be good. If the coil was sufficient with the stock distributor, it should be good for the aftermarket. The aftermarket dizzy just times the firing of the coil.
Hook up of the coil is always the same.
Don't know about the connections of the aftermarket distributor. Hook it up per the mfrs instructions.
Good Luck.
Todd Bull.
