Disti install confirmation
Please confirm that the alignments of the dots on gears confirms I have the engine at TDC. Also, please confirm I need to keep trying to get the match marks to sync up. Please
View attachment 2270461View attachment 2270463
It appears you have the cams lined up on TDC. However, I believe that the cam timing is only related to itself. It could still be on the exhaust stroke and not the compression stroke. You could still be 180 out on the distributor, compared to what the valves are doing.
I don't see a mark on the distributor teeth to match those on the cam.
The main thing is that the cams are installed properly for the crankshaft. Then the distributor needs to be installed on the correct tooth, so that, when seated, the rotor is pointing at #1 on the distributor cap when the engine is one the COMPRESSION stroke, at TDC. At this point, both valves on #1 cylinder will be fully closed.
Do have the FSM?
So the rotor is pointing at #1, just left of the disti plug. If you look at the picture of the disti gear you can see the grove is just to the right of the grove on the disti, so not directly aligned.
I do have an FSM. Any idea which section I can find this procedure?
Section IG-11
Timing stuff also shown in EM-4, EM-5
It appears you have the marks in the correct location, but double check the distributor, as it shows those to be aligned BEFORE installation.
