Disc calipers/pads
SO.WEST,COLORADO
I'm in the middle of doing a RDB swap on my '78 40. Cheby 1/2 ton discs, monte carlo front calipers. My question is, how snug are the pads supposed to be on the disc. These seem petty dang tight, like having to beat them on. They are preloaded and new. :rolleyes:
Received the brackets today? ;)
Spacer is between the axle flange and the bracket? ;)
You should not have to drive the caliper onto the rotor...
No brackets yet, but have everything else. Had the rotors turned. The caliper is really tight. I opened up the bleed valve to see if it would help. Do you typically mill the rotors to the caliper width. If so, how much play should i have approx?, and what would be the minimum amount of material to have remaining on each side to be safe.
Caliper part # is 16-4072 L564 carquest, rotors are supposed to be chevy 1/2 ton, not sure of year as SAMSR(randy traded me for some other parts. He has used these same ones on his 40's and used monte carlo front calipers.
Nada, no numbers anywhere. I cleaned them up before and there is nothing.
the monte carlo calipers are for the 2wd 1/2 ton rotor , the 1/2 ton chevy calipers are for a 1/2 ton 4wd rotor which is .25" thicker. I think orange45 had to mill his pads down to get it to fit. I know because I did the opposite , I switched from carlo calipers to 1/2 ton off 86' K5 blazer and could not figure why the caliper piston had to come out .375 " to tighten on rotor , then I did the research and figured it out. Have you used a C clamp to compress caliper piston fully ????
. Have you used a C clamp to compress caliper piston fully ????[/QUOTE]
Yep.
Poser said:
Wrong rotor.....
Can you mill/sand down the pads a little to make them work. If so, how much should gap be when they are fully open. It sounds stupid to do this, but the closest machine shop is an hour away, and getting another set of rotors anytime soon is'nt an option.
