disc brake swap
Central valley (Cali)
Before i get bashed.... i read a good thread a while back but searched and could not find? looking to swap stock '66 brakes out for disc brakes (perferably chevy)my questions are what parts that i'm going to need ,should be new,and which ones can i get away with from the junk yard?Any help is great
thanks James:cheers:
I just got done doing disk brakes all around on my 64 (same as your 66).
The fronts are from an 82 toyota pickup. I had to get differential side gears and inner axle shafts from a 69+ Cruiser as well. I kept all of my stock steering setup (for now), but had the pickup steering arms 'fixed' by my machinist buddy. There's also a shim you can buy that solves that problem.
The rears are Monte Carlo calipers on Poser's brackets over chevy pickup rotors (again 'fixed' by my machinist buddy).
The master cylinder is from a 75 Corvette - apparently not many vehicles ever came from the factory with 4WDB and no power booster, but the 75 Vette did and the MC is pretty cheap. I built a fairly simple but burly-as-hell bracket to mount it, and extended the pushrod about an inch (1/2" steel tube sleeves it perfectly if you drill it out with a 3/8" bit) to make it all work.
Probably about $20 in miscellaneous brake lines and fittings from Napa, and enough custom flaring and bending to make me glad it's over...
I put a proportioning valve inline for the rears, but I'm not sure that it's even necessary. The front-rear bias from the MC is pretty good with my setup.
I haven't added it all up, but I think I ended up spending somewhere around $500 to do it all. That's more than I planned, but part of that was because I didn't want to mess around with the questionable used front calipers and bought new ones from Napa (only $40 a piece with exchange).
Let me know if there's anything else you need help with. I spent a lot of time searching for special inner axle seals for the front because I was told the stock toyota ones from a 69+ axle wouldn't work. They did. It's a long story, but not really worth telling. Just don't worry about it.
Eric
