Disc Brake Dilemma
Ohio
Working on a FJ60 disc brake conversion to a '71 FJ front axle and just realized that 1 threaded hole in the knuckle casting for the caliper (left wheel) is stripped out. In accordance with Murphy's Law, I didn't realize this until everything was cleaned/painted/assembled.
Do I:
1. Find another knuckle housing and go from there? (Had a real hard time finding an axle to get the parts from in this area)
2. Try to re-tap the hole and go with a larger bolt?
3. Oversize the hole and go with a threaded insert?
Lots of rotational force on those 2 bolts in a braking situation. I don't want the casting lugs to fail by going oversized if that is a possible consequence of options #2/3.
Thoughts??
I just did this and after considering all the options, rethreaded for a 1/2" fine thread bolt. The hole was already the right size so no drilling. I used a block with a hole the tap would barely fit through to keep me as lined up as possible.
I did it with the knuckle on so had to turn the tap with a rachet, but it worked out ok. Had to slightly enlarge the hole in the caliper to fit the 1/2" bolt.
GL
Ed
6 years ago I was doing a knuckle rebuild on mine and cross threaded
one of the caliper bolts. I ran the correct size tap through the hole but I still didn't like the way the bolt felt going in, so I got a Heli-Coil kit and repaired it that way.
Heli-coil is the way to go,There are lots of 60 cores in canada,but shipping would take a while.
Well, after alittle checking, it appears that the PO must have stripped the threads out and did a half-a%# job at tapping it out to 1/2". Bought a heli-coil kit and had it fixed faster than Landpimp can count all of his Cruisers. Mission accomplished-now on to the brake lines and master cylinder.
