Hello all,
I am currently having some issues with the lighting on my recently acquired '97 LX450. If all of the exterior lights are off and I press on the brakes, the taillights will illuminate extremely dim and the license plate lights will come on as well. The third brake light works normally. If I turn on the headlights, the taillights will not illuminate whatsoever, yet the third brake light will stay on regardless if the brakes are pressed.
Note, the gauges will illuminate with the headlights switched on, as will the side marker lights. I have replaced the fuse, both taillight bulbs, removed the trailer wiring and relay, as well as checked the harness and plug underneath the factory bottle jack. Nothing appears to have ever been wet in either quarter panel and all wires are intact.
Where should I look next? Is there a fusible link or brake light relay I should be investigating? Thank you all!
