Differential Lockers & CDL
Did you figure out how to get it out yet? I'm about to do the same thing.
Re-Visit
Can anyone tell me the proper ohm reading across the CDL switch? Mine works (sorta) its open when the ball is out and has like a 2.5 Megaohm resistance when pushed in. I suspect this is faulty as I would expect it to be minimal resistance when closed.
Thanks for the help.
Still hosed
Installed brand new switch from dealership and still no ABS and Center Diff lights.
The Center Diff is definitelty engaged by the switch.
Is it possible that whatever is supposed to push in the indicator switch on the transfer case is not working?
I suppose I could check it with a multimeter to see...
UGH!!! What a MFPITA
Sounds like your CDL actuator motor is toast. if your indicator switch is working then it will light up when the cdl is activated. It may "feel" like the center is locking up but its probably not. One way to know for sure is to put it in 4lo (cdl locked) then jack up one front tire and try to turn the front driveshaft. If you can turn the front driveshaft then your cdl is not locked. If you can't turn it then it is locked. As far as a CDL actuator motor is concerned, they run around $500 new from cdan or you could do what I did and try to find one if a salvage truck in the mud classifieds.
CDL definitely locked. I did the jack test and everything was good. Did a few more tests last night before the monsoon hit. I pulled the actuator and reconnected it to the wire. Had the wife turn the key forward and check for light as I cycled the switch in and out. NOTHING! So I checked the actuator with a multi and it works like a champ....So I jumpered the plug again and this time NO LIGHTS! I think this rig is like Christine or something.
The only thing that has changed since I last jumpered this plug with success is I did the 7-pin mod. Could I have screwed something up there?
Any help is greatly appreciated.
p.s. next is vacuuming out the 50 gallons of water in my floorboards and tackling that project. Does it ever end? LOL
OK - the hell with it. I'm going to take it to the stealership. I've exhausted every possible test imaginable. So damn frustrating.:bang:
Time for :beer::beer::beer::beer::beer::beer::beer::beer::beer:
there are two switches on the transfer case, the first tells the logic that the tcase is in low, that kicks in the CDL (unless you have done the pin 7 mod) the other reports that the CDL is locked and the logic will enable the front and rear lockers.
Are you sure you replaced the right switch?
I believe he did. See post #20.
Rick
Walleye, I've got the same exact thing going on. I've had the 7pin with cdl switch for a few years and never had an issue until I let the truck sit for a while. All of the tests check out and the axles locked when I did the paper clip test. Center diff is definatly locking when cdl is depressed. I thought about bypassing the actuator switch temporarily and hooking it up manually to a toggle switch. If you solve this, post up your results, I'll do the same.
Ordered the electrical diagrams book for my cuiser today. Hopefully it will help me hunt this down. I'll let you know.
You had the actuator out, how did you time it when it was installed? It maybe possible to have it timed so it doesn't shift all of the way, enough to partly engage the splines to lock, but not enough to hit the switch? Or the actuator maybe slightly bound and not allowing it to fully shift?
The light is a very simple circuit. The power comes from the gauge fuse, on when ever the key is on, if power is lost on that circuit all of the lights/gauges will go off. The ground side is switched by the CDL indicator switch. Pin 1 (white/black wire) on the switch connector is ground, from the bolt connector in the intake manifold. Pin 2 (yellow/black) (purple/black after the cowl connector to the cluster) goes to the light, in the cowl harness there is a splice and that wire (purple/black) goes to the diff lock ecu pin 15.
To test jumper pin 2 at the CDL indicator switch to ground, with the key to run the CDL light should light every time. If not you have a connection problem, but by far the most common problem is at the switch.
Excellent information. Thank you.
Can you please expound on the "from the bolt connector in the intake manifold"? I'm thinking when I did the valve cover gasket I may have severed this connection. What does it look like? Is it difficult to get to?
It's next to the brake booster, low on the manifold, a bolt with wires connected to it. I doubt it's your problem, that ground point also grounds the ECM, O2 sensors and a bunch of stuff, I would expect other running problems if it were bad.
To test, use your continuity tester between pin 1 at the CDL switch and ground, you should show a good connection.
:cheers: Fixed! THANK YOU Kevin and everyone else here at MUD. After I tried the Pin 2 to ground and got lights it was just a matter of tracing down the wires and low and behold the wire had been pinched so I cut out the pinched area and that did it.
I'm elated :bounce:
CDL and both Diffs now lock successfully.
I'd gladly buy a round of beers to all that helped me. :beer: Lets hope we all meet up sometime so I can make good on that.
