Differential General Health
Atlanta GA
Front Diff with factory locker of unknown mileage or care. It's on the bench as we rebuild the axle out of the truck so I'm going through it. Measured specs below all look good except backlash, is (+.004/.005) way out and need adjustment or should I just leave it? I'm confident I can replace the pinion seal without disturbing the pinion shaft (good posts here for that) and it wouldn't take much to adjust backlash too, I'm just not sure it's necessary.
Companion Flange Vertical Runout: .001-.002 in.
Companion Flange Radial Runout: Unknown, couldn't get to it with my dial indicator.
Ring Gear Runout: .001-.002 in.
Ring Gear Backlash: .010-.011 in.
Preload (Total at Pinion): 10.6/12.10 in-lb
Wipe Pattern: Unknown, I tried grease but it was hard to read. Ring gear teeth are undamaged and look evenly worn across the working surfaces of both sides.
Thanks, S.
Yep, with it on the bench it was easy to to adjust backlash while measuring preload at companion flange but it didn't change much. Then moved to pinion seal and replaced that, again confirming preload torque at companion flange. All good and ready to go back in.
