Different type of ATM
Belgium
Hi, I have a 2002 European hdj100.
The transmission seems to be different than what I can find online. First of all, I seem to have a different type of oil pan. The regular pan gasket doesn't fit. I doubt a bit that the regular strainer will also fit. The pan has a dipstick tube that runs from the rear of the pan all the way up to the left side of the motor (LHD). The pan only has a drain plug and not the overflow plug and the fill plug is not in the regular location. I do have something that looks like it could be the fill plug, but want to check with you guys. When entering my vin number in partsouq or other suppliers I get the regular gasket and strainer. Not sure what I'm looking at and even then, what type of oil to use on this one.
Yes, the metal tag in the engine bay says A442F.
Which gasket is used for this one?
It doesn't use a gasket but rather the Toyota FIPG (Form In Place Gasket) Orange from a squeeze tube. Can use aftermarket if Toyota unavailable. The screen is cleanable and reusable.
