Difference between 91 and 93 front axle assy
Emerald City
What are the differences between the 91 and 93 front axles ?
My 93 front end is all fawked up and I found a 91 front end for 500 bux with new rotors, pads and right axle/birf.
TIA
same same, unless the '93 has an elocker. Either way go ahead and swap 'em
My 93 is locked. I need everything from the spindle out on both sides. The guy says this one has brand new rotors and pads and a new right axle.
Thank you IBCRUSN
If it's a stock unmolested US spec axle, they are not the same. The birfs are shorter, the drive plates are shorter, the rotors are smaller, the calipers are different, etc.
Oops, your '93 probably has the shorter birfs/drive plates?
I think it depends on his 93.
My 94 IIRC has the shorter birfs.
I have one of those red headed step child 94's shorter birfs and such and a semi float rear and no abs.
But it should still bolt right up.
Just looked up the parts on rockauto and oreilys. They are different :-(
So I found some used spindles local, and I guess everything else will be new.
You're already using 16" wheels run it as is. If you're now running 15's pull the knuckles outboard off the '93 and install them on the '91.
IIRC the magic date for the birf and drive plate change is 4/94
BTW what's all fawked up on the '93?
I see the mess you're talking about now. Pull the spindles off the '91 and re-use them if they are in good shape, all the rest can stay '93 or new parts if they are beyond repair. The birf looks like a good door stop now.
