Diff, tcase and tranny oil change
Leesburg, VA
Can anyone shoot me a tech link that assists me with this simple task. I'm not mechanically uninclined....haha....but I've never changed these and want to get it right..
Where do I fill them and check the levels.....etc... I searched and see that most everyone uses 80w90....
Thanks......
Thanks......
Since I just did this I can offer some words of advice:
  • Get a really wide, high capacity oil drain catch pan (from Shucks or whatever). You need at least 9+ qt capacity (I have one that holds 14).
  • Buy several 5 gallon pails with lids from Home Depot. You'll need these to hold the old oil and to use to take the oil to be recycled.
  • Buy a good supply of paper shop towels. You will spill oil. And you do not want to contaminate your spouse's washing machine wth oil soaked rags. Trust me.
  • Draining the engine oil: Warm the engine up a bit. This will make the oil flow more easily. I forgot to do this when I did it.
  • Changing the diff oil: Be careful getting the drain plugs off. In my case the PO had mucked them up pretty good and I had a tough tme getting my box wrench on the rear plug. It was destroyed by the time I was done. I replaced them with an alan-key style from SOR so I don't have to deal with this in the future.
  • Draining the tcase/tranny oil: Depending on whehter the seal between the tcase and the tranny is (1) in good shape, (2) partially bad, or (3) totally bad you will either experience (1) a normal amount of oil draining out of each box, (2) tons of oil flowing out of the tranny FILL plug when you pop it off, or (3) tons of oil flowing out of the TCASE FILL plug when you pop it off.
  • If it's case (2) then you can install a return line between the fill holes of the tcase and tranny. If it's case (3) you need to replace the seal between them (my situation).
General instructions: http://www.autoblog.com/2006/03/29/autoblog-maintenance-101-oil-change/
:cheers:
Awesome....thanks for the post. I do not expect difficulties with the engine oil.....I am just somewhat hessiant about the others.....I beleive I know which are the drain plugs.....but not sure where the fill plugs are.....checking level....etc....
bd
Pictures of the T-Case and tranny fill holes
Fill 'em up to the bottom of the fill holes--in other words, until some fluid comes back out.
Tip 1: Buy yourself a gear oil pump (it mounts on the top of the oil container).
Tip 2: Gear oil flows better when warm.
