put HJ75(1992) into my FJ40 and front diff is not so good i can access lots of diffs here in oz, question is which diffs are compatible?thanks for any help,Baz
Aussie 25 said:If its a 92 landcruiser frount diff and it small like a hilux, its called a himount. and most probly a 4.11. A hilux one wont fit. You will have to get a nother HZJ75 or FZJ75 1990-1999. After 1999 thy change to 4.3.
what year and ratio in your fj40 ?
Hulsty said:Answer ? Early 40 had coarse spline diffs with a different flange etc and some had a 3.73 ratoi.
Best bet would probably be 60 series or pre 90ish 70 series diffs and swap on the appropriate flange, nearly all those diffs available locally would be 4.11 ratio
