can someone tell me i have a 97 8o triple locked how do i check they are working .the light up on the dash and flash any help apreciated
Find a dirt/gravel lots. Lock the CDL and do figure 8's, should feel some resistance (compare to open), then lock the rear, should feel more, then CDL, rear and front should free a ton.can someone tell me i have a 97 8o triple locked how do i check they are working .the light up on the dash and flash any help apreciated
^^^ This. Sorry, so used to having the CDL button added I forgot that first critical part. Thanks for adding.Just to elaborate a little, since you don't say if you have a center lock button installed, here's how you can test:
As stated, find a dirt / gravel lot. Shift the vehicle into 4 low. This should illuminate the ABS light and the center diff lock light. If it is flashing (meaning it is not locked), drive in figure 8s until solid. If you can't get it to go solid, you are done. The front and rear lockers will not work if the center won't lock.
If the center locks, turn the "magic dial" to lock both front and rear. If they flash, drive in figure 8s and they should lock (light stops flashing). It is possible that one or both may not lock (keeps flashing) no matter what you do. If that's the case, use the search here to find how to diagnose and fix. Lots of threads on that exact topic.
Good luck.
