diff gears what should i do..
hey all, im kinda new to the 80 series, and 4x4s in general really.. so heres my problem,probelly really stupid.. (and i have looked but cant find the answer i want)
Ive got a 3.5" lift and 315/75/16s tyres, now i need to change my diff gears.. as its an all wheel drive does this mean i need to change both diff gears?? or just rear? if i need to change both can i avoid this buy takin out the front drive shaft till i take it wheeling? it might seem like a hassle but it doesnt take much to do and its only for a short time till i get some more cash together?? sorry if these where stupid questions but im just really new to all this..and dont have a heap of money.. dazza.
YES. you have to do both the front and rear.
as I will assume your going to pay someone/shop else to do the install you might as well have them both done at the same time to save on cash.
so it might sound silly, but is it posible for me to change diff gears in rear, run it with out front shaft, then put it back in for wheeling? or will something s*** its self with 2 differnt diff gears?
Well, I suppose there would be some slippage in the tranfer case. But that would not be a good thing over time. Plus, when you engage low range in the T/C, there will be NO slippage and the gears will fight each other and something will have to give and that will cost more money than doing the gear swap (which you will have to do anyway!) Change them at the same time.
No, not possible. Yes, it will s*** itself quickly.
Plenty of folks run stock gears and 315s. Wait until you have enough to do both.
what diff gears (ratio) would you be looking for
I had been running stock gears (4.10's) with 35's for nearly 9 months without any issues. Power was a little lacking at freeway speeds and the truck would frequently unlock the TC to pull minor grades. But it did pull them without dropping out of overdrive. Offroad was not an issue either, but I did have to "gun it" a little more than I would like to have. This past weekend, I installed a set of 4.88's and immediately noticed the difference! Acceleration is much more brisk, and the engine is back in its torque curve at freeway speeds. No off road experience with them yet, but I imagine that will be an improvement over the 4.10's as well.
