So, I rerouted and extended my differential breathers and added the filters on the ends as suggested by Mud folks. The front sounded like opening a soda can when I pulled the hose off, so was a good thing. I'm sure the check valve was stopped up. I pulled the brass fittings both front and back to clean and degrease and found the rear is a full 1/8" or so inside while the front fitting is just a pin hole where the L fitting fits inside the housing. It seems to me the front breather is the more critical of the two, so anyone have any idea why Mr. Toyota thought a pin hole would be sufficient on the front breather fitting? Seems it will clog easily and won't provide much in the way of pressure relief. Anyone replace fitting with larger ID?
