Are my diff breathers supposed to have tiny hole? I just changed my diff oil and chose the Royal Purple. Front was milky
, but back was fine. I noticed my truck already had diff breathers with 12" extentions tubes with an ID of 1/4" , but the breathers themselves were plugged. There was a bit of pressure in both diffs when i removed the fill plug. The brass breathers needed a blast with carb medic to clear. That's when i noticed the hole in the centre of the breather was small, like 16GA wire small. Is that to prevent debris in genera? Should I bore it out a bit? The tubes didn't have a cheap gas filter on the end which I'll rectify but having pressure build up in my diff isn't good for the seals.
