Dieseling...
Orlando, Fl
its been a while since i've worried about my own fj40, but here we go. my 40 diesels when it shuts off, not every time, and almost never in a row.. but it does it when its been run a while, or run hard, or what not.... what can i do to stop this? and if i dont, how much damage can it do?
Jonathan/SandRider
my idle is way low, i dont have a tach, but i know that if i go much lower, it will stall, its that slow (i like the low rumble)
Be careful there. Remember at idle your engine is still having to pump oil. A very low idle is not such a good thing.
Do you have access to a timing gun?
If your 40 is too far advanced, you should turn it down.
As far as the idle, I believe you can adjust your idle at the carb.
re-check your timing after any idle adjustments at the carb.
Mine also occasionally thinks it's a diesel :D
Turned the timing back a notch, seems to have helped...
manny
I would do either;
A) back the timing off
B) change the plugs
C) adjust the carb back
D) run fuel additive or spray some Chemtool in the carb
E) change the distributor/wires/plugs
F) God help you if you get to F. All of the above or buy some C-4
I've always looked at dieseling like a 12 year old kid that talks so fxxxing fast that when he finally shuts up he's still talking.
HTH.
