Did I get the right shocks?????
In the redwoods
I just started to install my bilstiens and the practical measurements do not seem right.
Basic measurements are
Front center eye to center eye is 25 3/4"
rear is 21 1/2"
Front bump stop to axle is 8"
rear is 9 3/8"
The front new shock is only 3 1/2" longer than its static position. Which doesn't allow for more drop than that. And fully compressed is 3" shy of the bump stop.
The rear is only 5" longer than the static position.
Is this normal? What kind of travel do you guys have. Articulation is improtant.
When you guys hang a tire in the air on your rigs do the springs hold the tire or does the shock? Is a shock designed to hold the weight or rather can it?
Thinking that I have the wrong shocks...or maybe not...
Here is a better question.
Is it better to be able to stuff the tire into the front wheel well and the rear drop to it's max or ...
have the front be able to drop to it's spring max and the rear tire be able to stuff into the rear well?
I'm thinking of balance, and does the rear throw the cruiser over more or does the front?
It seems that I can't have both with shock travel.
We need your maximum droop and stuff for both front and rear. We also need to know what model # shocks or give us there fully extended and collapsed length. Without those numbers, we have no idea what you need.
Jeremy
Thanks Jeremy, I am sure I can get my drop for both the front and rear. Not sure on the stuff though. I will get some measurements up tomorrow night....Thanks
a nice big ditch is better for checking flex than a ramp (unless you run the ramp forward and backwards.
Longer shock mounts (ford ones) in the front will really help out. Also, you can redo your shock mounts in the rear. If you just move the top mounts further inward it will work but places more leverage on the shocks which reduces their effectiveness. I did it but leave my rs9000s on the stiffest setting.
btw, I use 9012s inthe front.
ps just measuring bumpstop to axle distance at a flat resting spot aint gonna cut it. You need to flex it up (stuff one tire and droop the other). My front end leverages off of the bumpstop and forces the droop side down further than if you just put a jack on the bumper and lift evenly.
