Diagnose (2) noises.
South Jordan, UT
Noise #1:
High pitched whistling when I put it in reverse. Most common after sitting overnight. Goes away in Park or any forward gear.
Noise #2: High-pitched ~scraping (different than noise #1) noise from the front end when braking, or sometimes turning (w/o braking). Not very loud--can't here it with the windows up. No vibrations felt through brake pedal. Much higher-pitch than typical worn-out brake pad noise.
Anyone?
Checked your brake pad thickness lately? If not, do so- it's too easy. Both noises could be wear indicators, or just shims vibrating.
-Spike
