Desperate Help Needed!!!
Charlotte NC
:censor: ....I am trying to remove my old stick shift tranny from the engine block, keeping the t-case installed....but the darn thing wont budge :mad: Can anybody tell me how to do it correctly....because obviusly i'm not doing it right :mad:
On a 75 FJ40...four bolts attach it to the bellhousing. (Pull the shifter, obviously. Then just slide it out. If it won't budge perhaps your pilot bearing is toast. I recall a thread about this a while back, I would do a search, you may have the same problem.
Good luck.
does the trans move at all vs the engine? or does it act like they are still bolted together?
Hurray......I got it. I was trying to remove it with the bellhousing still attached. I unbolted the tranny from the housing and put a hydraulic jack inbetween the T-case and the bellhousing and it slid right out and off. I had built a cradle out of 2x4s for the tranny to land in.....Like a charm ;) I should have drained the fluid though, because it spilled out all over my garage :doh:
