"Dent" in Axle Ball Normal?
Oxnard, CA
After some light wheeling today I noticed there's a visible (and feel-able) "dent" of a line in the driver's side axle ball. Is this normal/common? I haven't seen this on anyone else's vehicle, but I haven't looked at too many axles either. (Search turned up nothing for me). For background, the brown stuff is all fresh mud, the rest of the ball is smooth to the touch, and there's grease in the birfs via the dipstick test in the square fill plug.
Brandon, Your truck is SCREWED!!!!! I'll take it off your hands for you without even charging you for me to haul it away:flipoff2:
I don't think I would worry about it too much. It's probably been like that since new and you never noticed it before. If you had caused it you would know.
I seriously just read that as, "could a moose knuckle slap the ball..."
I've never noticed that line on my truck. Hopefully, people will post up with more experience. Any grease leaking out? Last front axle service? Condition of grease in the birf?
Well, moose knuckles are big and tuff. Seriously though, they all get a wear area from the dirt caught in the felts. But IME that wear is a smooth vertical line, not a dent, and it is located where the felts lay on the ball when the steering is in a neutral position.
From the photo (and description) it appears that this is a dent as well as being inboard of where the felts lay with the steering wheel level/straight. Maybe another couple of photos after it is cleaned up, with the wheels pointing straight forward and with the opposite side for comparison. My thinking would be to check to see that everything that holds the knuckle in place is tight as well as check that the felt/ wiper/steel is in place properly.
I have those same depressions on my 40 and have seen them on a few minis. My theory is that they are wear lines. The knuckles run in a short arc, close to centered most of their life and the felts/rubbers can get dirt/abrasive material embedded in them, causing them to wear those lines. I have never seen the depressions cause a problem and have done several axle services on axles with them without leakage or other issue.
Ive seen them on almost every 60 I have looked at closely recently (all over 200K miles) - and three axles out of 4 that I have owned recently all have a line to some degree. Doesnt seem to be an issue
Its due to corrosion, and normal wear ands tear - thats where the felt sits when the wheels are straight. You can fill it up with jb weld and sand it down if your anal about these things. Thats what I did with my 70 series.
Karl
Normal and fine. Your knuckle does look a little dry, however. You might gently clean that area with water and a toothbrush with any eye toward getting the crusted edge of the felt seal more flexible and recheck the grease in the knuckle. Should be grease on that surface.
DougM
