- Joined
- Feb 24, 2010
- Threads
- 2,226
- Messages
- 2,226
Avon Lake, Ohio (July 13, 2015)…In hot temps, both performance and factory fuel injectors can be at risk of vapor lock or heat soak causing a rough idle, slow starting or other potential serious engine problems. DEI has the solution by introducing Fuel Injector Reflective Heat Covers available in packs of two, four, six or eight, that reflect direct and radiant heat away from the injectors. Constructed of high-temperature rated glass fiber material bonded to a heat reflective aluminized material, DEI’s Fuel Injector Heat Covers can be used on most any engine configuration utilizing stock or aftermarket fuel injectors. Cooler fuel injectors will perform more efficiently, offering a more consistent throttle response.
Installation is a breeze as the injectors do not have to be removed. The covers are made with a split design allowing them to wrap around each individual injector and are secured with a sewn-in hook and loop fastening edge.
For more information about DEI’s Made in the USA Fuel Injector Reflective Heat Covers, visit www.DesignEngineering.com?utm_source=rss&utm_medium=rss, call DEI at 800-264-9472 or e-mail: Sales@DesignEngineering.com. To keep up with the latest new thermal performance products from Design Engineering, Inc. (DEI), like us on Facebook, or follow on Twitter.
About Design Engineering, Inc. (DEI)
Design Engineering, Inc., founded in 1995 by the late Dale Markley, is the leading aftermarket manufacturer and global supplier of performance heat and sound control products. DEI engineered products offer the most effective means to improve an engine’s cooling efficiency to enhance performance. Boom Mat, the company’s sound deadening product line, offer products that keep a vehicle’s interior cool and quiet.
Based in Avon Lake, Ohio, the company has continued to grow employing 30 under the leadership of the Markley family and through the expansion into new product lines including: Boom Mat™, Ny-Trex™, Radiator Relief™ and CryO2™. In addition to supplying the performance automotive aftermarket with thermal tuning products, DEI serves the needs of the powersports, marine, industrial and commercial industry markets worldwide.
The post DEI Introduces Fuel Injector Reflective Heat Covers – Designed to Prevent Vapor Lock and Heat Soak appeared first on RockCrawler 4x4 and Offroad Magazine.
Related posts:
Continue reading...
- Part# 010380 – 2 pack
- Part# 010381 – 4 pack
- Part# 010382 – 6 pack
- Part# 010383 – 8 pack
Related posts:
- Royal Purple’s Max-Atomizer: Spring Cleaning for Fuel Injectors and Fuel System Components
- Boom Mat Introduces:Jeep Wrangler Sound Deadening Headliner for 1997-2006 TJ's
- Royal Purple Introduces All-New Max-Clean Fuel System Treatment
Continue reading...
