Degreaser
ian
Coeur d'Alene, Idaho
Website
www.mahuron.org
Stupid rookie mechanic question:
I don't have a solvent tub and don't particularly like working with Xylene. So I bought some of this Castrol degreaser.. it's purple. It behaves like a detergent. It's cheap and works quite well.
Question is... once I clean parts with this junk, what should I rinse with prior to assembly. I'm worried that if I leave any on the parts, it'll act to break down the new lubricants.
Thanks!
I used the same stuff, It does work pretty well. Since its biodegradable. rinse the part really well with water. if you are painting something that has been degreased I would give it a quick once over with the Xylene. then paint away. Otherwise the Xylene should take any residue from the Castrol stuff away.
I try not to buy anything that has to go to hazmat. However, if it's a necessary evil, maybe I'll go pick up a *small* amount. IIRC, the last time I bought any xylene, it was in a 5 gallon barrel from the local PPG shop. Can smaller amounts be had elsewhere?
Try Lowes or Home depot. In the paint section. You should not have a problem getting some in smaller amounts.
** if you are ever going to durabak anything it might be handy to have a lot of it. They suggest to wipe down all surfaces to be durabak(ed) to remove grit, grime, dust etc.
Be careful with aluminum parts, as the Castrol product will corrode them. Rinse them with water immediately after cleaning them.
KLF did a test once to compare Castrol Super Clean to POR Marine Clean - he put some parts to soak overnight in aluminum cans. Both cans were empty in the morning because the solvent had eaten through the cans!
and for serious degreasing you can have big success with easy off oven cleaner, letting is soak a while, and then a trip to the car wash to rinse.
