Landpimp said:like I mentioned my 135 F doesn't get hot, new 190 t-stat, all gaskets ect. I think Mark told me his 135 runs cool also, don't think mine gets up to 160deg.
Don't need a radiator then!
IDave said:Don't need a radiator then!![]()
froggy said:Is the radiator on a F bigger than on a 2F? I have a 1977 2F engine in my 1971. My 2F runs cold like your F . Landpimp, do you have a clutch or direct fan?
and now with the addition of the two fans I'm very happy with the setup. I would like to change out the hoses but it was all I had at the time.Where did you get the fans? Part numbers? Cost?66fj40 said:I know the purests wont care for this but I went with the Summit Racing heater with the grill front. I added a couple of hoses to the front and ran them to the defrost/defog vent. I still wasn't happy with the defrost/defog and bought 2 40mm x 40mm x 10mm 12V computer cooling fans and put one behind each duct tube to force air to the ducts. The fans are on a seperate switch from the heater so I can control the defroster (and yes it will defrost now). The heater was sorta expensive a $160 but I like winter wheel'n AND being warmand now with the addition of the two fans I'm very happy with the setup. I would like to change out the hoses but it was all I had at the time.
OswaldtheBold said:Where did you get the fans? Part numbers? Cost?
IDave said:Whats the cfm on that, 66?
