Defroster output increased....
Lowered the windshield prior to putting the top back on. Discovered the gaskets on the cowl strip had shifted, as had the gaskets in the winshield frame. Basically they looked like dog bones, pinched in the middle, which reduced air flow.
Got some trim adhesive, and reset them.
One of them got a slight increase in airflow, the other got a pretty fair increase.
If you're not getting proper airflow from the defroster, might be worth a try to check these gaskets. Might not be a bad idea to routinely check prior to top reassembly.
Kinda' premature, aren't you? I heard a Portland broadcast predict 85 degrees down there today. It's getting warmer again.
We have (tracking!) snow predicted for next weekend. :D
35 degrees F at the moment.
It's getting nippy around here in the mornings...I just got all new door weatherstripping and defroster hoses. I'll check my WS gasket, too; thanks for the heads up! Maybe this winter I won't need my squeegee for the *inside* of the windshield. :)
