Decellerating wobble
Bradenton, FL
I am getting a wobble (1-2" on the steering wheel) whenever I come off the gas and apply the brakes. It just started a few days ago and only does it in the body roll (gas to brake) transition. These were replaced several weeks ago: TRE's, wheel bearings and rag joint and have minimal slop in the steering but the vibration just started. I dont have any play in the knuckle when you try and rock the tire in and out. I have 2 knuckle rebuild kits with all new bearings that I was planning to install when I had time. Wondering if I should make time to rebuild the knuckles or should I be looking at something else?
Is the wobble there when decellerating and NOT applying the brakes?
If it's only there when applying the brakes, then suspect something wrong with the brakes.
A warped rotor, for example, could cause this. Very severe hard spots from excessive heat can also cause this.
brakes
x2 on the brake rotors.
Every time I get the decel wobble it is fixed by getting the rotors turned..
I agree it could be brakes, but I have 4 wheel drums and they checked out a couple of months ago.
Oh, I didn't realize you had drum brakes.
Still could be the brakes,
could be tires out of balance,
could be worn shocks,
could be worn steering components,
could be ???
GL
Joshua
Leaking gear lube can cause drum brakes to grab. Might have a seal in the beginning of failure or possibly installed wrong or nicked during installation. Pull the drums and inspect.
I'll pull the drums and take a look. If nothings leaking I'll look into getting the drums turned if theres enough meat left.
