Dealer programmable functions? ('03)
Holland, Michigan
I searched, didn't find. The dealer is going to try to figure out why my engine runs rough, while it's in there I'd like to get some functions reprogrammed if that's possible. I'm only half-way through reading the owner's manual, so far I've seen various functions the dealer can change. The auto door locks are a big pain, they don't seem to unlock, and I keep going out to the truck to find most of the doors locked.
On the BMW site there's a list of cool things dealers can program, like driving lights on with high-beams, central locking options, climate functions, and various options that don't come standard. Is there any such list for UZJ100?
I found a thread about programming the auto door locks in the FAQ, and it's almost helpful. Apparently some 100s have instructions in the owner's manuals. Is there any info in there about how to disable the auto locks? What are the possible modes you can program? Maybe my year can't be owner programmed, but I'll be willing to try just in case.
Does this help?
Let me know if it was something else and I can try and copy it out of the manual, its an '06 manual and I haven't tried it...
—Automatic door locking and
unlocking functions
You can select the following modes of the automatic locking and unlocking functions. The initial mode is mode 1.
Mode 1—Automatic locking operation linked to shift lever position
All doors are automatically locked when the shift lever is moved out of “P” position after the ignition switch is turned to the “ON” position and all the doors are closed.
Mode 2—Automatic locking operation linked to vehicle speed
All doors are automatically locked when the vehicle speed goes above about 20 km/h (12 mph).
Mode 3—Automatic unlocking operation linked to the ignition switch All doors are automatically unlocked when the driver’s door is opened within 10 seconds after the ignition switch is turned to the “ACC” or “LOCK” position, or the key is removed.
Mode 4—Automatic unlocking operation linked to shift lever position All doors are automatically unlocked when the selector lever is moved to “P” position after the ignition switch is
turned to “ON” position.
SETTING FUNCTIONS
You can set the following functions by yourself. To set the mode 1 (the automatic locking operation linked to shift lever posi-
tion):
1. Set the parking brake, close all doors and turn the ignition switch to the “ON” position.
2. Shift the selector lever into the “P” position.
3. Press the driver’s side power door lock switch on the front side for about 5 seconds, within 10 seconds after the ignition switch is turned to the “ON” position.
4. The doors will be locked and unlocked to indicate that the function is set. To cancel the function, do the above op-
eration again.
To set the mode 2 (the automatic locking operation linked to vehicle speed):
2. Shift the selector lever from the “P” into the “N” position.
eration again.
To set the mode 3 (the automatic unlocking operation linked to the ignition switch):
2. Shift the selector lever into the “P” into the “N” position.
3. Press the driver’s side power door lock switch on the rear side for about 5 seconds, within 10 seconds after the ignition switch is turned to the “ON” position.
eration again. To set the mode 4 (the automatic un-
position):
4. The doors will be locked and unlocked to indicate that the function is set. To cancel the function, do the above operation again.
Great, thanks, this should be added to the FAQ on programming door locks. I don't see the option of leaving the doors unlocked, I'll see if the dealer can program that when I go in. If not, I'll try some of these.
