dead window question
Central Coast, CA
Website
www.coastal-aquariums.com
I did a search, but did not find exactly what I am looking for.
My ds front window on my 95 80 will not go down with either the PS switch or the DS switch. I am guessing it is a burn't out motor? (I just had a thought while typing this of applying downward pressure on the window while pushing a switch) Assuming this does not work, is there anything else it can be. I have not removed the door panel to see if it is a bad connection, but did firmly close the door a couple of times which was no help. Any idea on a price for a window motor?
Thanks
Thanks
See red highlight: I'm guessing you mean PS?
correct. Sorry about that. it is the front ps window that will not go down.
are you getting any movement at all? in other words can you see any evidence that the motor is trying?
we haven't really had the time to mess with it while the ride is parked, just while driving, but it does seem that nothing is happening at all. THat is why I thought it might be a dead motor, plus both switches do nothing.
I had a similar problem on another vehicle. It ended up being a bad motor and had to replace it. I really haven't heard a lot about bad connections to the motor. It's usually just the motor. You're going to have to get in there anyway so if it is a bad connection, it will be easy to trouble shoot.
