Dead Cruiser No Power
Orange County, CA
I have 1997 80 with the Karr security alarm.
The battery in the remote lock was low and I had a trip to Big Bear planned; so I figured to just use the key and not bother with the remote. I had no issues with the truck that day, the following I went to start the truck and there was no power- lights, door locks, brake lights, or ignition all dead.
My first thought was that the alarm was set and not de-armed and that was why it would not start. I called Karr, they stated that the alarm does not interupt the lights or radio. The sales guy said to check the fusible link, I searched the forum and read the 4 or 5 post- not sure if this is my poblem.
I replaced the battery 3 months ago, other than that no work has been dome on the truck.
  1. The fusible link, what will it look like when it has failed?
  2. To my understanding there are 3 links comming off the battery, if the main link fails would that be the only solution for having no power at all?
  3. Has anyone had a problem like this that were on the alarm side and not the power side?
Any help would be appreciated.
Thanks
The obvious (which you haven't stated) - did you put a new battery in the remote to see if it fixes it?? Lotta potential time chasing down electrics here, so start with simple stuff like that one.
Next - you have also not mentioned looking at your fuses - both underhood and dashboard...??
DougM
No offense. Did you by any chance leave the lights on over night? They would drain the battery.
