De-Smogged MPG
Gardnerville, Nv
In an attempt to cure the hot start issue in my 91', I decided to finish the de-smogging process. It had no effect on the problem, but my fuel economy greatly increased. On the last tank before the de-smog, I got 9.5 mpg. My commute is about 7 mi, stop and go with a top speed of 45-50. First fill up after the de-smog, 12.55 mpg. It also runs and drives a lot smoother.
Have you tried moving your EFI relay inside the cab? The hot start issue is typically related to the EFI. I had a hot start issue a week or so ago and took the 30 minutes to move it inside the cab. No issues since. We reached 90 today and I would've had issues today.
I also noticed a huge improvement in MPG when I eliminated my EGR, VSV, air pump, etc. About a 2 mpg increase. Only one full tank through but I didn't change driving pattern. If anything I am pushing it a little harder because I have noticed more low end torque.
It never crossed my mind... I would be interested to see how you went about moving it. At this point it's worth a shot!
Go to this link. Post #11074 I used an old relay. Popped the metal top off, delicately. Then trim the tabs inside to fit the connectors tight. Used some wire I had laying around and ran it inside under my dash. One of the issues with the 3FE is that the exhaust manifold is about 16" from the Fuse/Relay box under the hood. At some point I may move the Fuse/Relay box elsewhere but for now it works perfectly. I had everything laying around so it didn't cost me anything. If you don't have everything it may cost you $10-15.
In the meantime if you have the "no start when hot" issue, carry a spare EFI Relay part # 90987-02004 and swap it out if your truck won't start. Careful, the existing relay will be HOT! If you don't happen to have a spare, shame on you, buy one for $10, you can also use one of the relays in the driver's kick panel below the dash. There are 3-4 of them there. You might lose your lights or heater or something but you will be able to get home. :)
https://forum.ih8mud.com/threads/what-did-you-do-with-your-80-this-weekend.586191/page-554
I'm definitely going to do that this weekend. It bothers me how hot my EFI relay gets. For what it's worth, when it won't start, I have tried swapping the relay out for another and it makes no difference. I plan on doing a bunch of wire inspecting and electrical diagnostics this weekend.
