Dayum! Cross threaded/stripped ATF drain plug!
Ashland, OR
I did the ATF flush last week and when I drained the pan the bolt was not normal when I unbolted it. When I buttoned it up it was definitely f'd. Now it is dripping!:crybaby:
I have not drained the pan to check it yet but lets assume it is stripped. Has anyone delt with this? I am hoping the fix is not a new pan. Just looking for a could be scenario...
:cheers:
Try to retap the original threads and if that fails tap for a sliiightly larger bolt?
Going through this now...Went to do a drain and fill but the plug wouldn't come out :frown:...But it did loosen up enough to start dripping :bang:
For a temp fix I cleaned off the plug area with brake cleaner and quickly and liberally applied some gasket sealant/maker. I was surprised that after a few days it stopped dripping entirely :hhmm:. And no, I'm NOT out of ATF :hillbilly:
I opted for a new pan from Dan that just arrived :) - I have not yet removed the old pan and at this point I am just hoping to get the plug out so I can drain the fluid so I don't have to remove the pan full of ATF. I'm hoping to salvage the old pan for possible future use, maybe.
Options I considered: trying to retap; getting an oversized self tapping plug (bought one at Napa but didn't use it); new pan. After seeing just how few threads there actually are on the captured nut inside the pan (looking at the new one), I'm glad I opted for a new pan. I'd have to go look again but there are only like 2, maybe 3, complete sections of thread in there :eek:
Note to self : in the future use a new crushable gasket each time I do a drain and fill and ONLY tighten the bolt just enough to crush the gasket. If no drip then call it good. If slight drip, SLIGHTLY tighten the plug just a skosh and check again.
These are tough to tap for some strange reason. I tried with each of the previous two tranny pans I've had this issue with....both times the tap failed and caused more dripping. I've replaced the pan twice and am looking at #3 coming up soon.
The pans are not expensive, all things considered.
-o-
When you have the tranny properly serviced at the dealer, they drain, then drop the pan and clean the screen filter. This gets more fluid out and obviously cleans accumulation off the screen so it's a good thing. Get a new pan and drop it off with the truck to have a tranny service done. If they tell you it will be extra to install the new pan, tell them to f/o and go somewhere they will not try to rip you off at every point. What do they care when they go to reassemble - grab the old pan or grab the new pan?
DougM
Well I feel better that I am not the first with this issue! I am thinking a new pan is the ticket. I'll talk with the parts guru to see how much it will be.
Thanks!
mmm.... wondering if one could use parts of an old pan as a second layer "skid plate"...? :)
Nah, would make a great baking pan for a LandCruiser themed birthday cake, though!!
DougM
DougM
Or jello mold!
I will keep the old one as a trail spare. Of course I will need a trailer for all the "trail spares" I am collecting!
