Dash warning lights issue
OOCustoms
GOLD Star
Nantucket
Ok, so over the last couple of weeks 4 of my dash warning lights simultaneously have illuminated randomly, at first if I cycled the vehicle on/off they would disappear for a few key cycles, then reappear again. 2 days ago they came back on and stayed on. I disconnected the battery for an hour, reconnected, still on. My scanner says zero codes. No warning tone. Brakes feel fine, no leaks. Vehicle seems to function perfectly. Thoughts?
Recent brake system work? How long does the brake master pump run before it shuts off? Accumulator holding pressure?
Transfer case sensor(s). Possibly a sub harness failure between the engine harness connectors and the transmission/transfer.
The bottom row is a dead giveaway; your ECM thinks you're in LO range.
That's probably not the only problem, but that's where I'd start.
I have the same 3 lights intermittently OP. Off and back on again for a while now. No other symptoms/codes
I have yet to officially diagnose but my search initially led me to the ABS VSC module:
Interesting… up until about a month ago, the center diff lock dash lights never came on when locking the diff (confirmed it was engaged). We had a blizzard several weeks ago, while driving around with the diff locked the lights suddenly started flickering on when I’d make a turn or hit a bump. They worked intermittently for about a week, then quit again.
