Dash light question
Richmond, VA
OK..here's the question...
I got some trailer lights to put as front side markers since mine were gone. Well...I got some crappy ones that only have a pwer wire and ground throught the bolt that attaches them.
While I was figureing this out an changing headlight...the 2 wires on the sidemarket made contact..and since I didn't unhook the battery like a moron....I popped the fuse for the sidemarker/tail lamps. No biggie...toss in another fuse and the tail lamps and side markers work fine...but now I have no dash light. Instrument cluster or heater controls. The dash fuse is fine...is there any other inline fuse I may have shorted that I have overlooked?
I think their is a relay for the dash and heater controls. Mines is located under the hood release. They are hidden up under. If not I have noticed some relays under the right kick panel on the floor. That is were I would start.
It might help to look through this web page for some wire diagram.
Master Portal - forums.bauchan.org.
Actually...I just did some fooling around with the wires. I find it better at night...because I can see the lights when they work..but can"t see what I'm doing. :D
I think this is related to my rear 1/4 chop. All of those wire at the tail light and marker lights have been exposed to salty roads for a long time and every connections is weak. I fiddled withthe side marker lights and the dash lights came back on...so it looks like I found my problem.
I doubt I'll replace every connecter, but I'll probably slather them with dielectric grease and see if the fuse keeps popping.
