dash is loose
The passenger side of my dash is very loose and bouncy. How do I reattach it so it stops rattling and shaking?
Thanks D,.
Mine also came loose, but later type dash so different bolt locations. The FSM shows them, on mine had to remove a couple of vents, some behind the glove box, etc, made a big difference.
The far side of mine was loose and bouncing over bumps. Turned out to be a spot weld that had broken on one of the dash support brackets. I'm a welder so I was able to fix it. My other option would have been to drill through where the spot weld was, and use a blind rivet (pop rivet) to re-attach the bracket.
Hopefully you just have a couple loose bolts. That would be easier.
Same as me but I went with a 1/4" pop rivet and some epoxy.
