Hi all, long-time follower, first time poster.
Thought I’d post this for anyone wondering about instrument cluster compatibility, specifically upgrading an early 2007–2011 200 Series cluster to the mid-facelift 2012–2015 version.
I can confirm the later cluster is a straight swap into the earlier vehicle. The two rear connectors are identical, it plugs straight in, and in my case everything worked correctly — gauges, warning lights, steering-wheel controls, gear display and all MID functions, including the factory digital speed readout.
One important thing: make sure you also grab the matching 2012–2015 instrument cluster surround/trim. The original early-model trim will not fit over the later cluster because the housing and centre display are taller.
I fitted a 2013 URJ petrol Sahara cluster into my early petrol UZJ 200 Series and it has been faultless so far. I can''t see why the diesel would be any different. No fault codes, speed reading is accurate, and no wiring changes or coding were required.
