- Thread starter
- #21
I've never driven a 200, but I've got to think that using the crawl function in that scenario was just driver error. It's meant for when you want to "crawl."
Yes -- crawl UP slippery rocks. Like slate.
Gotta be something wrong? The one time I was stuck, I had all 4 wheels spinning trying to free myself. I never had any cut out or anything. I even remember my buddy telling me to cool it at one point because all it was doing was digging me in further.
Unfortunately I don't remember what I had on or off, but I'm pretty sure I was in 4lo with diff lock on and VSC off.
I found this in my manual. on page 238.I'll reproduce it here for the benefit of those that have not seen it and to clarify what I posted earlier.
"TO DISABLE ACTIVE TRC AND/OR VSC SYSTEM
If the vehicle gets stuck in fresh snow or mud,Active TRC and VSC system may reduce power from the engine to the wheels.You may need to turn the system off to enable you to rock the vehicle in order to free it.
Turning off Active TRC
Quickly push and release the button to turn off Active TRC."
(this is the button next to the centre diff lock button and illustrates a car skidding and the word "off")
"The slip indicator light should come on.Push the button again to turn the system back on.
Turning off Active TRC and VSC
Push and hold the button for more than 3 second while the vehicle is stopped to turn off Active TRC and VSC.
The slip indicator light will come on and the "VSC OFF" will be shown on the multi-information display.
Turning off VSC
Push the centre differential lock/unlock switch to turn off VSC system.
The centre differential lock indicator light will come on and VSC OFF" will be shown on the multi-information display.
Push the switch again to turn the system back on."
Wow. Don't see it necessarily as a sarcasm from a low tech and jealous 80 owner, but IMHO wheelers will soon need a degree in astrophysics!In order to disable BOTH TRC and VSC, you must lock the CD and then HOLD THE TRC button for 3 seconds.
You mentioned you were stuck in mud? Was this after the wet slate climb, or were you stuck in some sort of slate/mud concoction?
How did crawl work on the wet slate? Was it at least worth it in that situation?
The only time I ever used crawl control was on two occasions...
1. Uphill rock climb. It was a dream as I drank my coffee and steered with the other hand. My buds were all nice a jealous!
2. Negotiating a tough off camber, rutted and washed out, steep downhill. There was definately some benefit to the crawl in that situation as my inexperience in wheeling would have for sure left me in a very expensive predicament. Infact, in the past I had gone around that section because of my fear, but the crawl handled it no problem.
The Crawl Control has it's place, and mud isn't one of them.
BTW...Now I know why this site is called IH8MUD? For the longest time I thought it was some sort of sarcasm, but this Damnit thread explains.![]()
LOL, I thought it was sarcastic too....until I had to drive in the stuff. It's nut fun giving the vehicle gas and having the system beep like crazy and tell you that you can't.
I've used crawl control both up and down some very steep stuff and it does work. BUT -- not when it's wet and the wheels are loosing traction. The area I was in had deep mud pits with inclines of slate rock. The mud wasn't on the slate, but it was wet. And my tires were packed with mud.
.It kind of peeves me that you spend all this money on an off-road vehicle, and then you need to upgrade tires for any serious off-road duty. This is why my first mod was tires. I've had the BFG ATs on for a while, and everyday I'm thinking of even upgrading to mud tires.
It just doesn't make any sense...when I bought my RS6 it came stock with P-zero tires...Z rated tires for a car that can go that fast. It would be like selling me the RS6 with all seasons.
Sounds like you need new tires.
I'm not trying to stab anyone in the eye, just playing devil's advocate.
What about all the people who buy an Audi and have to put snow tires on even though its AWD?
As far as I know there isn't one tire for every situation. Therefore, every (tire) choice is a compromise in another area.
Thanks! I tried this earlier today and IT DOES WORK. In order to disable BOTH TRC and VSC, you must lock the CD and then HOLD THE TRC button for 3 seconds.
Now question 2: What is the difference between VSC and TRC? Maybe I'm just not getting what the difference is.
The way I see it, VSC is when the vehicle senses it's fishtailing, going sideways, or tilting too far. The TRC system is what needs to be disengaged to allow the wheels to fly free. Therefore, when you put the vehicle in 4LO, VSC is automaticly disabled (as seen on the info screen) BUT TRC is still on (even if you lock the CD). You MUST hold the TRC button for 3 seconds!
x2...![]()
Where is the mud?? This thing looks clean to me
BTW are they replacing the pump under warranty?
