damn cigarette lighter...
west chester, pennsyltucky
i have been reading some posts regarding the cigarette lighter in my lx450. several of the posts recommended that i remove the composite piece, reassemble and "viola" it will work.
i removed what i think is the afore mentioned piece, but when i plug it back in it immediately blows the fuse. what am i doing wrong? or what else do i need to address?
the piece i removed is the black piece in the threaded assembly which aligns the posts for the wiring clips. is this the correct part or did i remove the wrong one? if so, i didnt see any other composite piece in this area.
brasco
brasco
Good quality pics of what you're describing would help us help you. But, if that black piece you removed is an insulator, it might be shorting out.
Any composite piece in a lighter is usually for insulation. If you remove it it will short & blow fuses.
1st before anything you need a meter and verify its not grounded. Keep hooking a hot wire to it and you might experience some great fireworks.
There's a composite insulating washer with a thin wire crossing it, a fusible link. If you start taking the assembly apart from the back, starting with the small nut, you'll come to the washer and link (or remains of the link). It's an ordinary looking round washer with round hole, not a funky aligning washer. Remove the washer and reassemble, and it should work. I did this with both my 80s, one in a parking lot while my wife ran in for groceries on a cross-country drive. Small parts, best done on a well-lit table so you don't lose anything. I don't know what that fusible link is for, there's a fuse on the circuit already.
Just in the hope it helps I'll throw in a word of warning; the wire to our lighters isn't the ideal gauge to support the compressors and inverters and such that some folks use really regularly. I thought about removing that insulator too and decided against it. If you are going to do that and use the lighter for anything other than cigs, cigars and cell phones, you should also upgrade to a thicker wire. Just my humble and overly cautious opinion. :cheers:
That fusable link is a heat fuse. It is there to protect the system in the event your ciggy lighter gets stuck in the socket.
I have a question too. Mine stopped working after using am invertor and my gps was plugged in at the same time. The interesting thing was I checked my fuses under the dash and they all seem to be fine. Any ideas on what I need to replace to fix it?
Chris
thanks so much for your help guys.
as mentioned, the black plastic piece is an insulator. i replaced that and removed the small washer-looking piece between the 2 metal tabs. this has fixed the fuse blowing issue. i dont know if the cigarette lighter works yet but will test it in the next few days and will update.
if i had examined this a little closer, i could have avoided asking a stupid question, but maybe it will help someone else with the same problem.
thanks again to all who to the time to reply and help me with this.
brasco
