1977....
Provided a PO has not changed something with your tcase control linkage, you should have a male stud ball joint on the transfer case end of the range selector and a cotter pin keeping the link into the lever. If there is slop in any of these components, the lever will not be able to move the linkage enough to lock the case into high range.
Crawl under the truck and have someone move the linkage and watch it move from high to low range and back again, unless you can watch it through the hole in the tunnel and move it yourself...see if you can lock the range selector into high range by hand...If you can, drive the truck and see if it stays in gear...
If it does not, then you may not have a linkage issue and it may be something inside the case.
Verify the linkage first.
Good luck!
-Steve
